Varitec -- Redefining the internal combustion engine
5 replies to this topic
Poll: Varitec -- Redefining the internal combustion engine (6 member(s) have cast votes)
Varitec is a
  1. Great Idea (5 votes [83.33%])
    Percentage of vote: 83.33%
  2. Horrible Idea (1 votes [16.67%])
    Percentage of vote: 16.67%
Vote Guests cannot vote
#1 dwightlooi
dwightlooi
    OSV Member
  • Members
  • PipPipPipPip
  • 1,347 posts
Posted 07 April 2011 - 08:31 PM
GM Varitec Family
The Varitec Family of Engines…
Replaces the Family One, Ecotec and HF V6 engine families
Are designed to be most advanced, efficient and refined in their class
Share a standardized 98mm Bore Centers, 88 mm Bores and 88 mm Strokes
Span 1.6 to 6.4 liters with 3, 4, 6 and 12-cylinder variants
Ground Breaking Technologies
Homogeneous Charge Compression Ignition (HCCI) – At low engine speeds and load, Varitec engines operate without using the spark plug to ignite the fuel-air mixture. Instead, it increases the effective compression ratio and adjust the mixture to cause spontaneous ignition very much like a diesel engine. This enables up to a 20% increase in brake specific fuel consumption at cruising speeds. Varitec engines are capable of operating in HCCI mode between 1500 rpm 3000 rpm.
Tricam VVTLD – One Concentric and One regular cam shafts per bank affords Variable Valve Timing Lift and Duration control of the intake valves, as well as exhaust cam phasing. The ability to continuously alter the intake cam duration and timing allows the engine to negate up to 30% of the compression stroke and operate in Atkinson Cycle (or Miller Cycle) mode when maximum power is not needed. Atkinson Cycle operation creates a longer power stroke relative to the compression stroke improving energy recovery and fuel economy – Miller Cycle is similar concept but applied with forced induction. This ability to alter the effective compression stroke also allows for the effective compression ratio to be dynamically adjusted which is a necessary ingredient to enabling HCCI operation. Effective displacement of Varitec engines is variable from 70% to 100% of their swept volume during operation, whereas Effective Compression can be adjusted from 9.4 to 13.5:1 (8.2 to 11.7:1 on turbocharged applications).
Flywheel Integrated Generation and Starting (FIGS) – Varitec Engines do not have a belt driven alternator and a regular starter motor. Instead, they carry a 30 mm thick Generator-Motor in place of the flywheel. A 1.5 kW version provides basic electric generation as well as engine starting. As a standard feature, Varitec engines have the ability to automatically stop the engine when it is idled for over 5 seconds at standstill and restart it when the driver lifts the foot off the brake pedal. This feature is enabled when the transmission setting is in ECO mode. In vehicles equipped as mild Hybrids, a 15 kW Flywheel Integrated Generator-Motor offers up to 15 bhp / 80 lb-ft in electric assist in addition to electric generator and starting. Both the 1.5 kW and 15 kW FIGS operate on long life Lithium-Iron-Phosphate batteries. The basic Generator-Starter operates on a 12.8V electrical system, whereas the assist capable 15kW system runs at 115.2 V.
Refinement Tuning – The Varitec family is designed from the ground up to be the most refined engines in their class. This is achieved through four main avenues. The first is that all Varitec engines (except the V12 which is naturally balanced) feature balance shaft(s). This includes the 60 deg V6es – a configuration which traditionally do not receive a balancer because the 1st order vibrations are considered mild. The Second is an extensive strengthening of the engine blocks through the incorporation of isogrid girders in the exterior of the block and using a one piece lower block with cast in place bearings. Thirdly, the engines make extensive use of Helmholtz resonators and strategically placed insulation around the noisy direct injectors. Finally, because the Varitec family has the ability to adjust its effective compression, the engine automatically switches to the lowest compression ratio and maximum intake stroke negation during idle and low loads when not operating within the HCCI regimes. Incidental to the reduction in compression ratio is a reduction in combustion noise.
Varitec 3-cylinder Engines
Varitec 16 HCCI
• 1.6 liter Tricam-12v Inline-3; Naturally Aspirated
• Static Displacement 1606 cc
• Single Balance Shaft
• 1.5kW Flywheel Integrated Generator-Starter
• 135 bhp @ 6200 rpm
• 128 lb-ft @ 4200 rpm
• Redline @ 6200 rpm / Rev limit @ 6350 rpm
• 87 Octane Recommended
• Applications: Chevrolet Cruze 1.6, Sonic SS; Daewoo Tosca 2.1; Opel Astra 1.6
• Transmissions: Hydramatic 6T40 -6-speed Automatic; Getrag F28 6-Speed manual
Varitec 16 T
• 1.6 liter Tricam-12v Inline-3; w/ Honeywell-Garrett MGT1548 turbocharger
• 170 bhp @ 5200 rpm
• 175 lb-ft @ 2000~5000 rpm
• Redline @ 5200 rpm / Rev limit @ 6200 rpm
• Applications: Chevrolet Cruze 1.6T; Opel Astra 1.6T
Varitec 4-cylinder Engines
Varitec 21 HCCI
• 2.1 liter Tricam-16v Inline-4; Naturally Aspirated
• Static Displacement 2141 cc
• Dual Balance Shafts
• 180 bhp @ 6200 rpm
• 170 lb-ft @ 4200 rpm
• Applications: Buick Verano 2.1, Regal 2.1; Chevrolet Malibu 2.1; Daewoo Tosca 2.1; Holden Epica 2.1; GMC Terrain 2.1; Opel Insignia 2.1
• Transmissions: Hydramatic 8T50 8-speed Automatic; Getrag F28 6-Speed manual
Varitec 21 eHCCI
• 15kW Flywheel Integrated Generator-Motor
• 180 bhp @ 6200 rpm + 15 bhp @ 2800 rpm (Electric)
• 170 lb-ft @ 4200 rpm + 80 lb-ft @ 0 rpm (Electric)
• Applications: Buick Verano eAssist, Regal eAssist; Chevrolet Malibu ECO; Holden Epica Hybrid; Opel Insignia Hybrid
Varitec 21 T
• 2.1 liter Tricam-16v Inline-4; Honeywell-Garrett MGT2252 Turbocharger
• 270 bhp @ 6000 rpm
• 250 lb-ft @ 1600~5600 rpm
• Redline @ 6000 rpm / Rev limit @ 6200 rpm
• Applications: Buick Verano 2.1T, Regal 2.1T; Cadillac ATS 2.1T; Chevrolet Malibu 2.1T; Daewoo Tosca 2.1T; Holden Epica 2.1T; GMC Terrain 2.1T; Opel Insignia 2.1T
• Transmissions: Hydramatic 8T50 8-speed Automatic; Hydramatic 8L50 8-speed Automatic; Getrag F28 6-Speed manual
Varitec 6-cylinder Engines
Varitec 32 HCCI
• 3.2 liter Tricam-24v 60 deg V6; Naturally Aspirated
• Static Displacement 3211 cc
• 270 bhp @ 6200 rpm
• 256 lb-ft @ 4200 rpm
• Applications: Buick LaCrosse 3.2, Enclave 3.2; Cadillac CTS 3.2, SRX 3.2, XTS 3.2; Chevrolet Impala 3.2; Daewoo Veritas 3.2; GMC Acadia 3.2; Holden Commodore 3.2
• Transmissions: Hydramatic 8T50 8-speed Automatic; Hydramatic 8L50 8-Speed Automatic
Varitec 32 eHCCI
• 270 bhp @ 6200 rpm + 15 bhp @ 2800 rpm (Electric)
• 256 lb-ft @ 4200 rpm + 80 lb-ft @ 0 rpm (Electric)
• Applications: Buick LaCrosse eAssist, Enclave eAssist; Cadillac CTS 3.2e, SRX 3.2e, XTS 3.2e; Chevrolet Impala 3.2 ECO
Varitec 32 T
• 3.2 liter Tricam-24v 60 deg V6; 2 x Honewell-Garrett MGT-2052 Turbochargers
• 400 bhp @ 6000 rpm
• 375 lb-ft @ 2000~5500 rpm
• Applications: Buick LaCrosse 3.2T; Cadillac ATS 3.2T; CTS 3.2T, Escalade 3.2T, SRX 3.2T, STS 3.2T, XLR 3.2T; GMC Acadia Denali; Holden Caprice 3.2T
• Transmissions: Hydramatic 8T70 8-speed Automatic; Hydramatic 8L80 8-Speed Automatic
Varitec 12-cylinder Engines
Varitec 64 T
• 6.4 liter Tricam-48v 60 deg V12; 2 x Honewell-Garrett GT-2860RS Turbochargers
• Static Displacement 6422 cc
• No Balance Shaft
• 3kW Flywheel Integrated Generator-Starter
• 720 bhp @ 6000 rpm
• 700 lb-ft @ 1600~5200 rpm
• 91 Octane Recommended
• Applications: Cadillac STS-V, Escalade-V, XLR-V
• Transmissions: Hydramatic 6T100 6-speed Automatic
Edited by dwightlooi, 07 April 2011 - 08:32 PM.
  • 0
#2 dwightlooi
dwightlooi
    OSV Member
  • Members
  • PipPipPipPip
  • 1,347 posts
Posted 08 April 2011 - 01:33 AM
This of course is a depiction of what can be and may be, but not necessarily what is.
  • 0
#3 Z-06
Z-06
    Ultra Member
  • Admin
  • PipPipPipPipPipPip
  • 8,281 posts
Posted 08 April 2011 - 06:49 AM
Dwight, what about at least a V8 for the trucks and high performance vehicles?
  • 0
#4 dwightlooi
dwightlooi
    OSV Member
  • Members
  • PipPipPipPip
  • 1,347 posts
Posted 08 April 2011 - 11:25 AM
The reason there is no V8 is that the V8s remain on the Pushrod Small block architecture -- fortified with cam-in-cam Dual Independent VVT, Direct Injection and Cylinder Deactivation of course. A 6.2 liter Gen V small block so configured will probably be make 450~470 hp on premium and probably around 420 hp on regular. To get to a similar output, a 4.3 liter "Varitec" V8 will need to be making over 100 hp per liter. This means either forced induction or revving into the 7500~8000 rpm range. The engine will be more expensive, bulkier, heavier and probably no more efficient on fuel... which then beckons the question why? What does that get you? A bit more refinement? The balance shafted 3.2 60 deg V6es already get you plenty of that for the mainstream models, whereas a bi-turbo V12 caps off the ultimate luxury-performance class.
Instead of a high revving V8 or bi-turbo V8, I think the Corvette, ATS-V and CTS-Vs are better served with a compact, light, affordable and efficient Pushrod V8. The trucks even more so by a 87 octane compatible version of the small block as well as the 4.5 & 6.6 liter Duramax Diesels. In fact, it is probably not a bad idea to add a 4.6 liter V6 based off the 6.2 V8 for lower end trucks -- more power, more accessible torque than Varitec V6; much less expensive and less worrisome on maintenance than a bi-turbo V6. A 4-engine Pushrod lineup looking something like this...
Gen V Small Block Family
Common characteristics:-
  • 90 deg Aluminum block with high mounted camshaft
  • 111.76 bore centers, 103mm bore, 93 mm stroke
  • Direct Injection
  • Cam-in-cam dual VVT
  • Cylinder deactivation
Vortec 284
• 4.6 liter Pushrod-12v 90-degree V-6; Naturally Aspirated
• Static Displacement 4649 cc
• Compression Ratio 10.7:1
• 315 bhp @ 5600 rpm
• 315 lb-ft @ 3600 rpm
• Redline @ 5600 rpm / Rev limit @ 6000 rpm
• Applications: Chevrolet Caprice Patrol, Suburban, Tahoe, Silverado, Express; GMC Sierra, Yukon
• Transmissions: Hydramatic 6L50 6-speed Automatic
Vortec 378
• 6.2 liter Pushrod-16v 90-degree V-8; Naturally Aspirated
• Static Displacement 6199 cc
• No Balance Shaft
• 420 bhp @ 5600 rpm
• 420 lb-ft @ 3600 rpm
• Applications: Chevrolet Camaro SS, Caprice Pursuit, Impala SS, Suburban, Tahoe, Silverado; GMC Sierra, Yukon Denali; Holden Commodore SS
• Transmissions: Hydramatic 6L80 6-speed Automatic; Tremec 6060 6-speed Manual
SS 378
• No Balance Shaft
• Compression Ratio 12.3:1
• 470 bhp @ 6000 rpm
• 438 lb-ft @ 4800 rpm
• 91 Octane Required
• Applications: Cadillac ATS-V, STS 6.2, Escalade 6.2; Chevrolet Corvette
• Transmissions: Hydramatic 8L80 8-speed Automatic; Tremec 6060 6-speed Manual
SC 378
• 6.2 liter Pushrod-16v 90-degree V-8; 2.1 liter Eaton 4-lobe Roots Supercharger
• No Balance Shaft
• Compression Ratio 10.3:1
• 600 bhp @ 6000 rpm
• 600 lb-ft @ 3800 rpm
• Applications: Cadillac CTS-V; Chevrolet Camaro ZL1, Corvette Z07
• Transmissions: Hydramatic 6L100 6-speed Automatic; Tremec 6060 6-speed manual
Edited by dwightlooi, 08 April 2011 - 11:29 AM.
  • 0
#5 Potluck
Potluck
    Red-Line
  • Members
  • Pip
  • 206 posts
Posted 02 May 2011 - 11:29 PM
What kind of increase in costs over the engines they would replace are we talking? Some of these sound fairly advanced over your basic Ecotec 4-pot
  • 0
#6 dwightlooi
dwightlooi
    OSV Member
  • Members
  • PipPipPipPip
  • 1,347 posts
Posted 03 May 2011 - 08:26 AM
Strictly from a component standpoint, we are talking about a more complex intake cam assembly -- concentric shaft and an additional cam phaser -- and a set of cylinder pressure sensors. Probably less than a turbocharger, intercooler and their plumbing. Most of this is going to be R&D and proofing costs.
  • 0
Reply to this topic
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
