- Model Year(s):
- INFINITI / QX4
1997-2003- NISSAN / PATHFINDER
1996-2004- NHTSA Campaign ID Number:
11V244000
- Summary:
NISSAN IS RECALLING CERTAIN MODEL YEAR 1996-2004 PATHFINDER AND MODEL YEAR 1997-2003 INFINITI QX4 VEHICLES ORIGINALLY SOLD, OR CURRENTLY REGISTERED IN, CONNECTICUT, DELAWARE, IOWA, ILLINOIS, INDIANA, MASSACHUSETTS, MAINE, MARYLAND, MICHIGAN, MINNESOTA, MISSOURI, NEW HAMPSHIRE, NEW JERSEY, NEW YORK, OHIO, PENNSYLVANIA, RHODE ISLAND, VERMONT, WASHINGTON D.C., WEST VIRGINIA AND WISCONSIN. IN AREAS OF THE COUNTRY IN WHICH HEAVY CONCENTRATIONS OF ROAD SALT ARE USED, A MIXTURE OF SNOW/WATER AND SALT MAY ENTER AN ASSEMBLY LOCATION HOLE IN THE UPPER STRUT HOUSING, CAUSING WATER TO COLLECT AT THE MATING SURFACE OF THE STRUT HOUSING PANEL AND THE INNER HOOD LEDGE ASSEMBLY. OVER TIME, THIS SNOW/WATER AND SALT INTRUSION MAY RESULT IN CORROSION OF THE STRUT TOWER HOUSING IN SOME SUBJECT VEHICLES.
- Consequence:
THE STRUT HOUSING MAY CRACK AND PULL AWAY FROM THE INNER HOOD LEDGE ASSEMBLY. THIS MAY LEAD TO GRINDING NOISES, INCREASED STEERING EFFORT, AND POSSIBLY THE STEERING COLUMN TO BREAK, RESULTING IN THE LOSS OF STEERING CONTROL, WHICH COULD RESULT IN A CRASH.
- Remedy:
NISSAN WILL INSPECT THE STRUT HOUSING AND REPAIR THE VEHICLES AS NECESSARY, FREE OF CHARGE. AN INTERIM NOTIFICATION LETTER WAS SENT OUT IN MAY 2011. THE SECOND NOTICE WAS MAILED ON JULY 25, 2011. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
- Notes:
OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Transport Canada Recall # 2011165
Recall Date 2011/04/21
Notification Type Safety Mfr
System Structure
Manufacturer Recall Number R177 & R178
Units Affected74,983
Category SUV
Recall Details
On certain vehicles operated in areas of heavy road salt usage during winter months, a mixture of snow/water and salt may enter an assembly location hole in the upper strut housing, causing water to collect at the mating surface of the strut housing panel and the inner hood ledge assembly. Over time, this snow/water and salt intrusion may result in corrosion of the strut tower housing structure. If the vehicle continues to be driven in this condition, the strut housing may crack and pull away from the inner hood ledge assembly. Should the strut housing separate and contact the steering column upper shaft, the steering shaft could break. A loss of steering control could result in a crash causing property damage and/or personal injury. Correction: Dealers will inspect the strut housing and, if no corrosion or only minor surface corrosion is present, an anti-corrosion seal will be applied. If moderate corrosion is present, resin patches will be applied in addition to the sealant. If there is evidence of more significant corrosion, a metal reinforcement plate will be used to reinforce the strut housing assembly. In instances where it is impossible to repair the vehicle, Nissan will provide an appropriate remedy.
Year(s) Affected
INFINITI QX4 1997 1998 1999 2000 2001 2002 2003
NISSAN PATHFINDER 1996 1997 1998 1999 2000 2001 2002 2003 2004
I'm going through this at the moment. The left side front strut tower on my 1998 Pathfinder let go around 2 years ago, and I parked the car in the yard at that point.
Late last year I discovered the recall, and I had my pathfinder towed to the local Nissan dealer 4 weeks ago. It's been in their workshop ever since, waiting on Nissan's Insurer to decide if my car qualifies for a buy-back or repair. The dealer considers the car to be a buy-back candidate.
