Get the Cheers & Gears App! ×
Jalopnik: Ford "Bobcat" Dual-Fuel Engine CAD Renderings Give First Look At Future [Engine Pr0n]
Bobcat-Ford-CAD-1.jpgRemember the uber-secret Ford "Bobcat" dual-fuel engine — the one that squirts a shot of E85 directly into the cylinder chamber to create diesel-like performance out of a gasoline engine? Thanks to PickupTrucks.com, we've got this exclusive first look!
These CAD renderings, brilliantly pilfered from presentations given by Ford last month to the Department of Energy and Society of Automotive Engineers by PickupTrucks.com, show the first detailed look at the new engine that's expected to achieve fuel efficiency gains of somewhere between 25-30% over a standard gasoline engine. That'll even be a 5-10% increase over the EcoBoost engines!
Bobcat-Ford-CAD-2.jpgPickupTrucks.com claims, through a load of math-type stuff, that:
"...an experimental 3.5-liter GTDI EcoBoost engine modified with E85 direct injection and gasoline port fuel injection run on a dynamometer achieved a BMEP score of 305 psi (27 bar), which translates to approximately 553 pounds-feet of torque and 316 horsepower at 3,000 rpm (flat torque curve from 1,500 to 3,000 rpm). The experimental engine was limited by the engine block's ability to handle higher compression ratios."
That means it could have been even higher! For comparison purposes, a standard GTDI EcoBoost engine on a dyno was rated at 17 bar, which translates to approximately 350 lb-ft of torque and 300 HP at 4,500 rpm. Wowzers.
And at first we were just impressed with those pink double Air/Water-heat exchangers sitting on top of the engine. [PickupTrucks.com]
full?d=H0mrP-F8Qgo full?d=yIl2AUoC8zA full?i=1VBAtH1gt_E:DfTepWK5cg8:D7DqB2pKE full?i=1VBAtH1gt_E:DfTepWK5cg8:V_sGLiPBp
1VBAtH1gt_E
  • Who's Online   0 Members, 0 Anonymous, 82 Guests (See full list)
  • 2024 Acura TLX Refresh Pairs-Down Trim Levels
    A vehicle refresh can include updates to technology, slight design changes, and updates to interiors. For 2024, the Acura TLX is back with a few exterior design changes. The most prominent is the front-end with new grille. TLX still uses slim headlights but incorporates a better designed grille. At the side, both the regular TLX and A-Spec TLX come with new 19-inch five-spoke wheels in dark gray. Step-up to the Type S models come with 20-inch black wheels; Type S models can be had with high-perf
    Acura
    Factorial Energy Opens Solid-State Battery Production Facility
    Factorial loves to quote Thomas Edison who in 1883 said the following: "The storage battery is, in my opinion, a catchpenny, a sensation, a mechanism for swindling the public by stock companies." Factorial states that this sentiment is true and has been held over the last 138 years till now. Investing in solid-state battery R&D over the last 6 years has allowed Factorial to create their proprietary FEST (Factorial Electrolyte System Technology). Factorial held their
    Automotive Industry
    Mazda unveils the Iconic SP concept
    At the 2023 Tokyo auto show, Mazda unveiled a sports car concept. Originally named Vision Study Model, the Iconic SP, utilizes an interesting engine combination. This hybrid-rotary-powered sports car uses the twin-rotor rotary engine as a generator to recharge the batteries. Iconic SP is around 10 inches longer than Mazda’s compact Miata. Although Mazda hasn't disclosed the number of electric motors, they are the main propulsion system. As a range-extending EV, that rotary engine doesn’t dr
    Mazda
Hey there, we notice you're using an ad-blocker. We're a small site that is supported by ads or subscriptions. We rely on these to pay for server costs and vehicle reviews.  Please consider whitelisting us in your ad-blocker, or if you really like what you see, you can pick up one of our subscriptions for just $1.75 a month or $15 a year. It may not seem like a lot, but it goes a long way to help support real, honest content, that isn't generated by an AI bot.
