Toyota recalls 7,300 Camrys with potentially leaking brake tube
02/09/2010, 2:36 AMBY MARK KLEIS
In a separate and completely unrelated (to unintended acceleration cases, floor mats or brake pedals) voluntary recall, Toyota will be fixing approximately 7,300 2010 four-cylinder Camrys with a shorter-than-intended power steering pressure hose that can interfere with the braking system and cause a brake fluid leak.
According to the announcement made by Toyota late Monday night, the issue with the brake fluid tube begins when a crimp from the power steering hose comes in contact with the number seven front brake tube. If this occurs, the crimp can wear a hole in the brake tube over time and eventually lead to a loss of brake fluid.
Toyota says that there are no symptoms associated with this problem that a driver may notice until the leak has already begun. In the event that the brake tube is punctured and brake fluid begins to leak, brake pedal stroke and stopping distance will be increased due to a decrease in power-assisted braking.
Toyota says that the affected Camry models will need to be inspected by a dealers, and if necessary, adjust the space between the brake tube and power steering pressure hose crimp. In some cases, the dealer may replace the brake tube if damaged.
Camry owners will be notified starting in mid-February 2010.
http://www.leftlanenews.com/toyota-recalls-7300-camrys-with-potentially-leaking-brake-tube.html
