Nissan Cube Recalled For Lack Of 'Fuel System Integrity'
Richard Read July 26th, 2010
Nissan is recalling approximately 46,000 Nissan Cubes from the 2009 and 2010 model years. According to a report from the National Highway Traffic Safety Administration, the vehicles suffer from a fuel system flaw that could result in increased chance of fire during a collision.
Specifically, the NHTSA says that certain units of the Cube "fail to comply with the requirements of Federal Motor Vehicle Safety Standard No. 301, 'Fuel System Integrity'". Translation: in crash testing (particularly the rear moving barrier test), the Cube leaked more fuel than was acceptable under current safety standards. And of course, more fuel leaked during a crash means that there's a greater chance of that fuel igniting.
The fuel system flaw affects vehicles manufactured between January 30, 2009 and July 30, 2010. (Since we're only at July 26, that's either a typo, or this release came from the future.) To correct the problem, the NHTSA says that "Dealers will develop a special protector and attach it to the gasoline recirculation tube at the location of the filler neck connector". The recall will begin in earnest on or before August 30, 2010.
If you have questions, we suggest you call your local Nissan dealer, or ring up Nissan customer service at 800-647-7261. Alternately, you can call the NHTSA safety hotline at 888-327-4236 and reference campaign ID number 10V330000.
http://www.thecarconnection.com/marty-blog/1047556_nissan-cube-recalled-for-lack-of-fuel-system-integrity
Nissan recalls 46,000 2009-10 Cube models over fuel system integrity
by Steven J. Ewing (RSS feed) on Jul 26th 2010 at 2:28PM
Last month, the Lexus HS250h was the subject of a serious recall involving fuel leakage resulting from rear-end collisions. Now, Nissan faces a similar predicament involving 2009 and 2010 model year Cube hatchbacks, and the National Highway Traffic Safety Administration has issued a full recall, covering 46,000 Cubes built between January 30, 2009 and July 30, 2010.
Much like the HS hybrid, NHSTA cites that the amount of fuel leakage following a rear-moving barrier crash "exceeds the allowable limits," and that this could result in a fire. While a fuel leak is bad news, it's important to note that this NHTSA test isn't simply a case of a simple crash test and resultant fuel leak – the government agency's methodology includes striking the vehicle from the rear with a deformable barrier at 50 mph with a 70 percent overlap. Post-impact, the vehicle is then spun on its longitudinal axis degree-by-degree for a total of 90 degrees, somewhere along which a fuel leak was detected. While any fuel spillage is a bad thing, we suspect you can put any images of the massively overblown Ford Pinto debacle out of your head right now.
In any case, the full recall is expected to start on or before August 30. To fix the problem, dealers will install a special protector to the gasoline recirculation tube where it meets with the filler neck connector. Naturally, the service will be performed free of charge at any authorized Nissan dealer. The full details are available in NHTSA's press release after the jump.
Vehicle Make / Model: NISSAN / CUBE
Model Year(s): 2009 / 2010
Manufacturer: NISSAN NORTH AMERICA, INC.
Mfr's Report Date: JUL 21, 2010
NHTSA CAMPAIGN ID Number: 10V330000
NHTSA Action Number: N/A
Component: FUEL SYSTEM, GASOLINE:STORAGE
Potential Number of Units Affected: 46000
Summary
NISSAN IS RECALLING MODEL YEAR 2009-2010 NISSAN CUBE VEHICLES MANUFACTURED FROM JANUARY 30, 2009 THROUGH JULY 30, 2010. THESE VEHICLES FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 301, "FUEL SYSTEM INTEGRITY." WHEN THE VEHICLE WAS ROTATED FOLLOWING A REAR MOVING BARRIER CRASH TEST AS REQUIRED, THE AMOUNT OF FUEL LEAKAGE EXCEEDED THE ALLOWABLE LIMITS.
Consequence
FUEL LEAKAGE, IN THE PRESENCE OF AN IGNITION SOURCE, COULD RESULT IN A FIRE.
Remedy
DEALERS WILL DEVELOP A SPECIAL PROTECTOR AND ATTACH IT TO THE GASOLINE RECIRCULATION TUBE AT THE LOCATION OF THE FILLER NECK CONNECTOR. THIS SERVICE WILL BE PERFORMED FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR BEFORE AUGUST 30, 2010. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
Notes
OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
http://www.autoblog.com/2010/07/26/nissan-recalls-46-000-2009-10-cube-models-over-fuel-system-integ/
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
