Ford News: Ford Divulges Engine and Towing Specifications For 2015 F-150
William Maley
Has it really been seven months since Ford unveiled the 2015 F-150 at the Detroit Auto Show? Yes it has. Since that time, the blue oval has been keeping its lips shut on the power and towing numbers for the F-150. Well today, Ford has decided to reveal some of those numbers.
We'll begin with the new base engine, the 3.5L V6. Not be confused with the 3.5 EcoBoost, the new 3.5 V6 makes 283 horsepower and 255 pound-feet of torque. Compared to the outgoing 3.7 V6, the 3.5 is down 19 horsepower and 23 pound-feet. That shouldn't be as noticeable you might think as the new F-150 is about 700 pounds lighter than the current model. Towing and payload numbers for the 3.5 4x2 model stand at 7,600 and 1,910 pounds respectively.
Next up is the new 2.7 EcoBoost V6. Horsepower stands at 325, while torque is rated at 375 pound-feet. In the 4x2 guise, the 2.7 can carry 2,250 pounds in its bed and tow up to 8,500 pounds.
Ford hasn't released information on the 3.5 EcoBoost V6 or 5.0L V8 at this time.
Source: Ford
William Maley is a staff writer for Cheers & Gears. He can be reached atwilliam.maley@cheersandgears.comor you can follow him on twitter at @realmudmonster.
Press Release is on Page 2
ALL-NEW FORD F-150 2.7-LITER ECOBOOST V6 ENGINE DELIVERS V8 CAPABILITY AND PERFORMANCE
Tougher, lighter 2015 Ford F-150 welcomes two new engines to its four-engine lineup, providing choices to meet almost any customer need – from hauling tools to towing trailers
High-output 2.7-liter EcoBoost® with standard Auto Start-Stop broadens engine lineup by providing mid-range V8-like towing capability of 8,500 pounds, payload of 2,250 pounds, 325 horsepower, 375 lb.-ft. of torque
Standard 3.5-liter V6 engine with twin independent variable camshaft timing delivers impressive power and efficiency with towing of 7,600 pounds that can't be beat, 1,910 pounds of payload, 283 horsepower and 255 lb.-ft. of torque
Use of high-strength steel and high-strength, military-grade, aluminum alloy plus smart engineering saves up to 700 pounds, improving power-to-weight ratio and allowing for gains in towing, performance and efficiency
With its new 2.7-liter EcoBoost® with standard Auto Start-Stop and new 3.5-liter V6 with twin independent variable camshaft timing, the 2015 Ford F-150 resets the bar in light-duty pickup truck performance, capability and efficiency.
"The 2015 F-150 is the most capable F-150 yet, while shedding up to 700 pounds," said Bob Fascetti, vice president, Powertrain Engineering. "These two new V6 engines – the 2.7-liter turbocharged EcoBoost and normally aspirated 3.5-liter Ti-VCT – set a new standard for Ford for capability and efficiency."
2.7-liter EcoBoost power
The high-output, twin-turbo 2.7-liter EcoBoost V6 features an entirely new design that delivers power and performance in a strong, smart package. The engine produces 325 horsepower and 375 lb.-ft. of torque – improving the power-to-weight ratio of the 2015 truck by 15 percent over the 2014 5.0-liter V8-equipped F-150 with similar torque output, thanks to vehicle light-weighting.
The 2.7-liter EcoBoost 4x2 has a maximum payload rating of 2,250 pounds and maximum tow rating of 8,500 pounds, ideal for meeting mid-range capability needs.
Boosting 2.7-liter EcoBoost fuel efficiency is the debut of standard Auto Start-Stop technology for F-150. This technology, specially tuned for truck customers, shuts off the engine when the vehicle is at a stop. When the brake is released, the engine restarts quickly. Auto Start-Stop helps reduce fuel consumption and emissions when the truck is stopped and the engine is off. The technology is off when towing or in four-wheel-drive mode.
The 2.7-liter EcoBoost engine also features Ford's first use of a compacted graphite iron cylinder block in a gasoline engine, the same material used in Ford's 6.7-liter Power Stroke® turbo diesel V8 in Super Duty trucks. The composite CGI/aluminum cylinder block saves weight while providing strength where it's needed most for durability.
Advanced technology, power and efficiency combine to create an engine for F-150 that boasts more than twice the horsepower, torque and towing capability of the Toyota Tacoma midsize pickup truck with identical displacement 2.7-liter four-cylinder engine.
Ford testing shows the 2.7-liter EcoBoost also outperforming Ram 1500 3.0-liter V6 EcoDiesel and Chevrolet Silverado 1500 5.3-liter V8 while towing a 7,000-pound enclosed trailer up Davis Dam in Arizona. This is the same grade the Society of Automotive Engineers uses for its J2807 towing testing standards, which the 2015 Ford F-150 will follow.
3.5-liter V6 tuned for responsive power
Thanks to vehicle weight savings, the standard 3.5-liter V6 with Ti-VCT offers a 5 percent improvement in power-to-weight ratio over the larger 3.7-liter V6 in the 2014 F-150, with better fuel efficiency and performance.
The 3.5-liter V6 produces 283 horsepower and 255 lb.-ft. of torque. The engine has a maximum payload of 1,910 pounds and a maximum tow rating of 7,600 pounds – unsurpassed for standard V6 light-duty pickup trucks.
Designed for impressive power and durability, the 24-valve 3.5-liter V6 features a valvetrain with direct-acting polished mechanical buckets with twin independent variable camshaft timing for impressive torque across a wide rpm range. Six-bolt main bearing caps, a fully counterweighted forged steel crankshaft and cast exhaust manifolds are designed for heavy-duty operation.
Both the upper and lower intake manifolds of the 3.5-liter V6 are tuned for responsive power, and both the intake manifolds and cam covers are composite-formed to reduce weight. The die-cast aluminum cylinder block features bay-to-bay breathing to reduce internal pumping losses, while a deep-sump oil pan contributes to extended oil-change intervals.
Advanced materials save weight
Extensive research by Ford engineers led to the use of more advanced materials on the 2015 F-150 than found in previous trucks. Military-grade aluminum alloys make the new truck's body lighter, stronger and more resistant to dents.
Overall, F-150 is up to 700 pounds lighter – helping the truck tow and haul more, accelerate and stop faster, and operate more efficiently than the previous F-150. High-strength steel in the frame and high-strength aluminum alloy throughout the body produce an inherently stiffer truck with greater dent and ding resistance. The aluminum upper body sits on a fully boxed ladder frame with more high-strength steel than ever to make it stronger yet lighter.
In addition to the new V6 engines, the all-new 2015 F-150 offers the proven 3.5-liter EcoBoost and the 5.0-liter V8 with Ti-VCT, providing a comprehensive, capable and efficient engine lineup to meet the specific needs of Ford truck customers.
Interesting, I wonder how long these engines will last in the real world of use and abuse by average Joe! Be interesting that is for sure.
  • Upvote 1
Good numbers for such a small motor.  I agree with dfelt though.  With the abuse and neglect a lot of trucks get subjected to, I would be more comfortable with a larger-displacement, understressed powerplant.
I almost never see pickups towing or even hauling that much.  I think a lot of truck guys just like having a truck, and a lot of truck guys take care of their trucks too.  The 2.7 Ecoboost puts up some impressive numbers in the power department, with the weight loss, the F150 with this engine might crush what Chevy or Ram have, minus the diesel from Ram.
Initially till they release better engines but then these little engines are your 100K engines as disposable trucks and this I believe is what the auto companies are hoping for well built but short life as people recycle them for a new one. I doubt you will see a Million mile 2.7L V6 Eco Boost F150 pickup. We see plenty of beefy V6 and V8 vehicles hit this but you can go only so small before you just stress the engine all the time to run and it wears out fast.
The F150 also weighs 750 lbs less than the Ram or Silverado, plus don't they have a 10 speed automatic in the works, so how high is this engine going to have to rev when it also makes a lot of low end torque.  The 3.5 Ecoboost has been around about 5 years or so, I haven't read or heard a whole lot about them falling apart.  Only time will tell, but just because it is a 2.7 liter engine doesn't mean it will fall apart.
Memo to Ford, drop that old 3.7 liter V6 in the Mustang and go with a 2.3 and 2.7 Ecoboost combo.
We can only surmise how much the coke can F-150 will weigh, based on Ford's published data.  GM fullsize trucks have traditionally weighed less than their cross-town counterparts.
Yea need to Bing or Google 3.5 ecoboost problems. Tons of them including lawsuits. Plenty of Service bullitins on how to try and hope it fixs some of the issues.
The national highway safety board this year has 1000 complaints about ecoboost issues from acceleration to hung throttles.
Yes FORD had had great growth on the EcoBoost engine line, but there is clearly plenty of problems and the forums show this to be true with many trading in their Ecoboost and going back to the Smooth dependable V8. There is also the complaint about gas mileage not being what is promissed.
Here is just one of the lawsuits: http://www.autonews.com/article/20130515/RETAIL/130519929/lawsuit-claims-defects-in-ford-3.5-liter-v-6-ecoboost-engine
Also I would like to see how these coke cans hold up in the various crash tests. I wonder how easily they will fold.
Aluminum is stronger than steel, so the F150 should be fine.
I am all for V8s, my car has a 5.5 liter V8, but I am also in favor of progress, so if someone can make more power and use less fuel then I think that is a good thing.  Really I am surprised more of these light duty trucks don't have a diesel, when diesels will last forever and produce monster torque.
So we have people steeling the copper wiring off of DOT projects to resell to the scrappers, so then we see a higher auto theft of the pure Aluminum auto's to resell as scrap? :P
Go back to high school physics class and relearn. The major draw for aluminum is that weighs nearly third of steel alloys. Aluminum generally is 33% less stronger than steel hence usually requires approx. 50% more thickness to match steel properties. Aluminum is not as malleable and ductile as steel is so the aluminum structures are difficult to work with. When you start using HSS then aluminum is moot.
That is why I think Ford is gambling big time with aluminum, it looks good on paper for Autoblog boys or you to go All Hail Ford, but let the accidents with those trucks sink in and then we can talk. Progress for name sake of progress is sometime retrogression. GM trucks with hydroformed chassis and panels and usage of HSS is actually metallurgically superior to Ford. Mullaly to me has always been big on creation of perception without significant substance and this is what he is banking on. I give credit to Ford with Focus, Fusion and new Mustang but I have never been sold on Mullaly as Ford's messiah.
Traditionally GM trucks have been 300 - 400 lb lighter than Ford trucks, so that claimed 700 lbs decrease is only a 300 - 400 lb (6 -8%) decrease for GM trucks, nothing it cannot achieve.
  • Upvote 1
  • Social Stream
  • Similar Content
    • By David
      Since Ford Motor Company reported a complete Q4 / 2020 fiscal year report with a loss of $2.8 Billion but a doubling of R&D on EVs to $22 Billion from $11 Billion and a $7 Billion for EV Autonomous driving, the auto reporters are asking this very question: Is this a Shot across gm's bow or is it targeted more broadly across the whole industry as everyone wants to take sales away or greatly slow down Tesla.
      Tesla's valuation appears to be based on investors putting money with new technology seems to be driving changes of the future.
      gm has now committed to moving into the technology camp with a solid date of when new ICE auto's will no longer be produced as the whole portfolio will change over to EV's. Ford also is now committing to this same strategy. This now makes one wonder about the rest of the auto industry.
      Stellantis CEO did an interview with Forbes that has put cold water on Peugeot coming to the US in the near term future as he wants to invest in the existing US name brands and grow their 12.7% market share. He also said that Stellantis has the manufacturing power and EV technology, but getting it into the hands of everyone is the concern at reasonable prices. Stellantis CEO says this is in the hands of the various global governments as he wants cleaner air and believes diesel the dirtiest of fuels will die off before regular petrol and where dictated by governments such as China and Europe will see a faster change over than other countries. Yet with the change in administration in the US, he says this could move the Stellantis brands to move into the full EV camp at a future date.
      Then we have small countries that have decided to make a major change in moving the country into EVs way sooner than other places and killing ICE sales like Thailand. This will allow local Thai startups to compete for the first time with international companies that also do not have anything in the market yet.
      With a large range of battery plants coming online over the next 18 months, the move to EVs could happen at a pace that took decades for ICE in the early 1900's.
      So this brings this back to the original question, Is Fords Doubling commitment to EV's and moving ICE into the last generation like GM a shot across GM's bow or a shot at the whole industry to say, look at us, we are moving into a Technology driven auto company and our stock should be much higher like Tesla's.
      Currently gm is valued at just under $80 Billion, Ford is valued at $40 Billion, Tesla is valued at $807 Billion, Toyota is valued at $155.5 Billion, Stellantis is valued at $50.5 Billion, Daimler is valued at $71 Billion, BMW valued at $46 and VW is valued at $90.7 Billion and while there are plenty of other auto companies, one has to wonder what Ford is focused on with the drastic change and speeding up of moving to EVs as a complete global portfolio.
      Sound off and discuss how, what, where and when you think this will have it's big affect.
      Charged EVs | Is Ford’s increase in EV investment a shot across GM’s bow? - Charged EVs
      Stellantis CEO Reveals Peugeot U.S. Fate, Job Security, EV Conflict (forbes.com)
      Future Toyotas, Stellantis, batteries and EVs - the week | Automotive Industry Comment | just-auto (just-auto.com)
    • By William Maley
      We've been reporting on Ford's upcoming truck, the Maverick since 2018. The truck would sit underneath the Ranger and become the entry-level model for the brand. Now, we have gotten our best look at what it will look like.
      The Maverick Truck Club forum got its hand on an image showing a prototype Maverick on the line reportedly at Ford's Hermosillo, Mexico plant. Up front, the Maverick borrows some ideas from the Bronco Sport with C-shaped headlights and a horizontal bar splitting the grille. We don't know if Ford is planning to offer any cab configurations aside from the crew-cab seen in the photo.
      Ford did not immediately reply to comment on this when reached out by Roadshow.
      The Maverick is expected to use the C2 architecture which underpins the new Escape and Bronco Sport. Autoblog speculates there could be two rear suspension setups based on spy shots that show a mule with twist-beam style setup with no rear differential for the front-wheel driver version. A slightly beefier setup might be used for the all-wheel drive version.
      Right now, everyone seems to think that the Maverick could debut as a 2022 model year vehicle.
      Source: Maverick Truck Club, Roadshow, Autoblog
      Pic Credit: Maverick Truck Club
    • By William Maley
    • By William Maley
      Jim Hackett's tenure as Ford CEO will be coming to a close on October 1st as he will retire from the position. His replacement is Jim Farley, currently Ford's Chief Operating Officer, a role he took on at the beginning of this year. In a press release, Ford said the two will be working together over the next two months on the transition. Hackett will stay on as "special advisor" for some time after.
      “I am very grateful to Jim Hackett for all he has done to modernize Ford and prepare us to compete and win in the future. Our new product vision – led by the Mustang Mach-E, new F-150 and Bronco family – is taking shape. We now have compelling plans for electric and autonomous vehicles, as well as full vehicle connectivity. And we are becoming much more nimble, which was apparent when we quickly mobilized to make life-saving equipment at the outset of the pandemic,” said Ford executive chairman, Bill Ford.
      Hackett became Ford's CEO in 2017 after the ousting of then CEO Mark Fields. His short tenure brought forth some major and controversial decisions such as Ford killing off most of their passenger car nameplates to focus on trucks and utility vehicles; spending $11 billion in electric vehicles by 2022, and the introductions of the Mach-E, 2021 F-150, and Bronco. He has also dealt with a lot frustration from various groups as The Detroit News outlines,
      Hackett admitted that his tenure did cause a fair amount of friction, but said his efforts are starting to show.
      "I aimed for moving ahead versus just moving fast. Could we aim for a longer-arc kind of reward. In this case, for the three years it takes to get products to market, you're starting to see the fruits of our labor."
      Farley, who has been with Ford since 2007, knows he has a tough road ahead. Aside from realizing the various paths laid out by Hackett, he also has to deal with the issues of the COVID-19 pandemic and hopefully launch two of Ford's key product without any issues.
      Source: Ford
      FORD ANNOUNCES JIM HACKETT TO RETIRE AS PRESIDENT AND CEO; JIM FARLEY TO SUCCEED HACKETT AS COMPANY CONTINUES TRANSFORMATION
      Jim Hackett, who has led Ford Motor Company’s transformation since 2017 as president and CEO, has elected to retire from the company Jim Farley, currently chief operating officer, becomes president and CEO of Ford effective Oct. 1. He was also elected to the Ford board of directors. He will work closely with Jim Hackett on the transition over the next two months Seamless CEO transition underscores strength of Ford’s leadership team, succession planning, and company progress over the past three years, Executive Chairman Bill Ford says DEARBORN, Mich., Aug. 4, 2020 – Ford Motor Company today announced that Jim Hackett, who has led the company’s transformation since 2017, plans to retire from the company. Jim Farley has been named the company’s new president and CEO and will join the board of directors, effective Oct. 1.
      Hackett, 65, and Farley, 58, will work together on a smooth leadership transition over the next two months.
      Under Hackett, Ford moved aggressively into the new era of smart vehicles and drove a deeper focus on customers’ wants and needs. At the same time, Ford improved the fitness of the base business – restructuring operations, invigorating the product portfolio and reducing bureaucracy.
      “I am very grateful to Jim Hackett for all he has done to modernize Ford and prepare us to compete and win in the future,” said Bill Ford, Ford’s executive chairman. “Our new product vision – led by the Mustang Mach-E, new F-150 and Bronco family – is taking shape. We now have compelling plans for electric and autonomous vehicles, as well as full vehicle connectivity. And we are becoming much more nimble, which was apparent when we quickly mobilized to make life-saving equipment at the outset of the pandemic.”
      Farley, an automotive leader with deep global experience and a successful track record, collaborated with Hackett over the past three years to develop and execute Ford’s Creating Tomorrow Together plan to transform Ford into a higher-growth, higher-margin business.
      “Jim Farley matches an innate feel for cars and customers with great instincts for the future and the new technologies that are changing our industry,” Bill Ford said. “Jim’s passion for great vehicles and his intense drive for results are well known, and I have also seen him develop into a transformational leader with the determination and foresight to help Ford thrive into the future.”
      Farley joined Ford in 2007 as global head of Marketing and Sales and went on to lead Lincoln, Ford South America, Ford of Europe and all Ford global markets in successive roles. In April 2019, Farley was chosen to lead Ford’s New Businesses, Technology & Strategy team, helping the company determine how to capitalize on powerful forces reshaping the industry – such as software platforms, connectivity, AI, automation and new forms of propulsion. He was named chief operating officer in February of this year.
      Hackett, who will continue as a special advisor to Ford through March of 2021, said the time is right to pass the mantle of leadership to Jim Farley.
      “My goal when I took on the CEO role was to prepare Ford to win in the future,” Hackett said. “The hardest thing for a proud, long-lived company to do is change to meet the challenges of the world it’s entering rather than the world it has known. I’m very proud of how far we have come in creating a modern Ford and I am very optimistic about the future.
      “I have worked side-by-side with Jim Farley for the past three years and have the greatest confidence in him as a person and a leader,” Hackett said. “He has been instrumental in crafting our new product portfolio and redesigning our businesses around the world. He is also a change agent with a deep understanding of how to lead Ford in this new era defined by smart vehicles in a smart world.”
      Said Farley: “I love Ford and I am honored by the opportunity to serve and create value for Ford’s employees, customers, dealers, communities and all of our stakeholders. Jim Hackett has laid the foundation for a really vibrant future and we have made tremendous progress in the past three years. I am so excited to work together with the whole Ford team to realize the full potential of this great company in a new era.”
  • Reader Rides
