ccap41
GT350R at GoodWood Festival of Speed
So bad-arsed in every way.
I could care less if this thing is in last place at the track, because it's looks and sound trump everything else.
Luckily for Ford fans, last place is not in this thing's lexicon. :thumbsup:
If anyone was concerned about lack of torque in a small-ish 5.2L NA engine, then watching this thing try to launch through the first few gears, even with those steam roller tires, should calm that concern right down.
  • Upvote 1
I can't stop watching this video.  So much awesomeness!
  • Upvote 2
  • Social Stream
  • Similar Content
    • By Drew Dowdell
      The folks over at Hagerty found something interesting on the NHTSA website the other day, a VIN decoder ring that shows a second 2.3 liter 4-cylinder turbo with a horsepower rating of TBD.   Ford dropped the V6 in the base Mustang after 2018 deciding the Turbo-4 was enough, but crosstown rival Chevy kept their V6 going alongside their 275 horsepower 2.0T.  While Ford's 2.3T beats the Chevy Turbo in power, it comes up short against Chevy's V6.  With this finding, it looks like Ford is going try to rectify the deficit.
      Given that a similar 2.3T is good for 350 hp in the Focus RS, Ford should be able to easily surpass the 335 horsepower the Camaro V6 produces.  A statement from a Ford representative declined to give details but said that we would have exciting news about Mustang in Spring 2019.
    • By Drew Dowdell
    • By William Maley
      The Ford Ranger is beginning to hit dealers, but it has already been hit with a recall.
      Ford announced today that 3,500 Rangers in North America (3,000 in the U.S. and 500 in Canada) have an issue with the PRNDL bezel wiring, The problem deals with the wiring interfering with the shifter interlock override, preventing the transmission from locking when put into park. This means you can shift it out of park when the vehicle is off and without a foot on the brake.
      Ford says that it is unaware of any accidents or injuries arising from this issue. The trucks involved were built between June 4, 2018 and Jan. 9, 2019.
      Dealers will investigate whether or not the truck does shift out of park when it is turned off, and without a foot on the brake. If it does, then dealers will relocate the harness and perform the test.
      Source: Ford
      Ford Motor Company Issues Recall For Select 2019 Ranger Vehicles To Verify Shifter Interlock Functionality
      DEARBORN, Mich., Feb. 6, 2019 – Ford is issuing a safety compliance recall on certain 2019 Ford Ranger vehicles to verify shifter interlock functionality. In the affected vehicles, the PRNDL bezel wiring may interfere with the shifter interlock override, preventing the shifter from locking in the park position and allowing the driver to shift the transmission out of park with the vehicle off and without a foot on the brake pedal.
      Ford is not aware of any accidents or injuries resulting from this condition.
      This action affects approximately 3,500 Ranger vehicles in North America, including approximately 3,000 in the United States and 500 in Canada.
      Affected 2019 Ranger vehicles were built at Michigan Assembly Plant, June 4, 2018 to Jan. 9, 2019.
      Dealers will verify shifter interlock functionality by attempting to move the transmission shifter out of park with the vehicle off and without a foot on the brake pedal. If the shifter moves out of park, dealers will look for wiring interference, relocate the wiring and retest. The Ford reference number for this recall is 19C02.
    • By William Maley
      Source: Ford
    • By William Maley
      With new versions of GM and Ram Trucks' heavy-duty pickups coming around the corner, it comes as no surprise that Ford has decided to update their F-Series Super Duty trucks. The big news is what resides under the hood.
      Taking the place of the 6.8L V10 engine is a new 7.3L V8 engine. Ford isn't detailing any specs on this engine, but is claiming that it will be the most powerful V8 in the class. The V10 produced 362 horsepower and 457 lb-ft of torque, and could tow up to 33,000 pounds.
      The 6.7L PowerStroke turbodiesel V8 engine has been updated with a larger turbocharger, fuel injection system, and upgraded internals. Again, Ford is keeping mum on specs. The base 6.2L gas V8 engine remains unchanged.
      All engines come paired with a new ten-speed Torqueshift automatic transmission that slots in the same space as the previous six-speed automatic.
      The exterior gets new front end styling to improve cooling, along with new LED lighting. Other changes for the 2020 model include more active safety equipment, 4G LTE Wi-Fi hotspot, wireless phone charging, and Pro Trailer Backup Assist.
      The 2020 F-Series Super Duty arrives at dealers this fall.
      Gallery: 2020 Ford F-Series Super Duty
      Source: Ford
      New Ford F-Series Super Duty Pickup Raises Bar Again With Next-Level Capability, Power And Technology
      Next-level capability: New 2020 F-Series Super Duty will offer its highest-ever conventional, gooseneck and fifth-wheel towing and payload ratings Next-level power: Most powerful Super Duty yet launches with two new engine offerings including all-new advanced 7.3-liter gasoline V8 and upgraded third-generation 6.7-liter Power Stroke® diesel V8; all-new heavy-duty 10-speed TorqShift® automatic transmission Next-level technology: New F-Series Super Duty now offers class-exclusive Pro Trailer Backup Assist, while its Trailer Reverse Guidance is now compatible with fifth-wheel and gooseneck trailers; standard FordPass Connect™ with 4G LTE modem and available wireless charging keep you connected; smart driver-assist features such as automatic emergency braking are standard on XLT series and above DEARBORN, Mich., Feb. 5, 2019 – Ford, America’s truck leader, introduces the next level of Built Ford Tough heavy-duty pickup truck capability, power and technology with the new 2020 F-Series Super Duty pickup.
      “Super Duty customers have demanding and diverse needs – from towing heavy trailers to repairing critical infrastructure,” said Kumar Galhotra, Ford president, North America. “Productivity is their lifeblood and their truck is their biggest tool. Our new Super Duty has more power, more payload and towing capability and better technology than ever to help these customers build a better world.”
      F-Series Super Duty had the most market share in industries such as government with more than 60 percent share, petroleum with 50 percent share and utility services with more than 45 percent share, according to Ford analysis of IHS Markit TIPet U.S. registration data, January 2017 through November 2018. Assembled in the United States, Ford’s F-Series Super Duty is built with pride at both Kentucky Truck Plant in Louisville and Ohio Assembly Plant in Avon Lake.
      New F-Series Super Duty improvements include new gas and diesel engines, an all-new 10-speed automatic transmission, chassis upgrades, exterior and interior design updates, and smart advanced technology that raises the bar again in towing, payload and connectivity.
      All-new powertrains for improved performance and capability
      An all-new Ford-designed and Ford-built 7.3-liter V8 joins the standard 6.2-liter V8 in Super Duty’s gas engine stable. The Ford-designed and Ford-built third-generation 6.7-liter Power Stroke® diesel V8 is upgraded to deliver more power and torque. An all-new Ford-designed and Ford-built 10-speed heavy-duty TorqShift® automatic transmission is paired with the 7.3-liter V8 and third-generation 6.7-liter Power Stroke® diesel V8. Ford is the only manufacturer to design and build all of its heavy-duty engine and transmission combinations – ensuring the powertrain works seamlessly with all chassis components and vehicle calibrations.
      “With the addition of the 7.3-liter V8, upgrades to our 6.7-liter and the debut of an all-new 10-speed transmission, we are delivering the strongest, most capable Super Duty powertrain offerings yet,” said Mike Pruitt, Ford Super Duty chief engineer.
      The 7.3-liter gas V8 engine delivers high performance in a compact package. Based on decades of commercial engine experience, this 7.3-liter is expected to be the most powerful gas V8 in its class – providing durability, ease of maintenance, and the towing and payload capability customers want. It uses an all-new cam-in-block, overhead valve architecture with cast iron block and forged steel crankshaft for maximum durability. Port injection with variable-valve timing optimizes the intake and exhaust to match performance with workloads. Oil jets cool the pistons under heavy loads.
      Super Duty’s third-generation 6.7-liter Power Stroke includes a new 36,000-psi fuel injection system with all-new injectors that precisely meter and spray up to eight times per stroke to control noise levels and optimize combustion. This innovative inboard exhaust diesel V8 features a redesigned electronic-actuated variable-geometry turbocharger that provides improved pumping efficiency and throttle response. Structural enhancements increase the strength of the cylinder head, block, connecting rods and bearings to handle higher cylinder pressure and increased output. New steel pistons provide higher firing pressure capability and less friction – meaning improved performance and more horsepower and torque than ever.
      The truck’s standard 6.2-liter gas V8 rounds out the three engine choices for Super Duty customers. This workhorse offers heavy-duty truck customers proven capability at an affordable price.
      Ford is making its all-new 10-speed TorqShift automatic transmission available across all three Super Duty engine offerings for the new 2020 model. This TorqShift features a wider gear ratio span than the 6-speed and is designed for the harshest towing conditions. The heavy-duty transmission continues to offer class-exclusive live-drive power takeoff, which allows the operator to engage industrial equipment and accessories, such as snowplows, with the truck in motion.
      This electronically controlled transmission has selectable drive modes that include normal, tow/haul, eco, slippery, and deep sand and snow. The entire unit is so cleverly engineered that – even with four extra gears – it fits in the same space as the 6-speed and weighs only 3.5 pounds more.
      Technology that assists and improves productivity
      For 2020, class-exclusive new Pro Trailer Backup Assist makes negotiating even the largest trailers into the tightest of spaces easier than ever before. With hands off the steering wheel, drivers use the Pro Trailer Backup Assist knob to easily steer the trailer via the reverse camera. The truck’s Trailer Reverse Guidance system shows trailer angle and direction, and provides steering suggestions to most efficiently direct a trailer backward. Both systems are built to accommodate all trailer styles, including fifth-wheel and gooseneck trailers.
      Because today’s work is a 24/7 proposition, staying connected is essential. Every new 2020 Super Duty includes FordPass Connect™ embedded 4G LTE modem with Wi-Fi access for up to 10 devices, keeping crews in communication no matter where the job might take them.
      Available lane-keeping alert helps you stay between the lines on the road, while the Blind Spot Information System with trailer coverage monitors for vehicles in your blind spots – even when towing. Pre-Collision Assist with Automatic Emergency Braking and Pedestrian Detection aids in avoiding or mitigating collisions with other vehicles and pedestrians. These features are standard on XLT and above Super Duty models. Modern touches include the addition of wireless charging and USB-C ports to power your devices.
      Powerful upgrades inside and out
      Across the range, an enhanced front-end design allows for optimized cooling and lighting performance under heavy loads. For the first time, all dual-rear-wheel Super Duty trucks are fitted with a uniquely designed high-airflow grille optimized for maximum powertrain cooling.
      Super Duty’s LED headlamps have a new look with improved performance, while high series trucks feature continuous signature lighting. An improved front bumper and air dam optimize cooling and make using utility hooks easier. A freshened tailgate design, revised taillamps and new rear bumper convey bolder Built Ford Tough style.
      Decorative appliqués on the doors and media bin door have been updated on Lariat, while on Platinum edition trucks, these pieces have been updated to Onyx Argento wood. The interior of the Limited model is completely refreshed, with colors updated to Ebony and Highland Tan to provide a refined, modern feel. Limited features authentic materials like genuine leather, a coarse ash wood in black and modern brushed aluminum trim. Crafted details include decorative stitching on the leather-wrapped instrument panel topper, wrapped door armrests, seating and center console lid, and an embroidered Super Duty logo added to the floor mats. A soft headliner in Miko® suede is intended to give the cabin an expansive feel.
      Tested to Built Ford Tough standards
      The new F-Series Super Duty debuts as the most tested pickup in the company’s history. It endured more than 12 million miles of testing for the 2017 model year, which was increased by an additional 7 million miles for 2020 to ensure the new Super Duty can stand up to the rigors the most exacting truck customers demand of it. This torture includes running the truck around the clock under the most extreme loads and through all kinds of environmental conditions using dynos, test tracks and public roads. Because the testing surfaces and durability test tracks are so punishing, many of the miles are run using robot drivers that can handle the abuse better than humans to ensure every F-Series truck is Built Ford Tough.
      Ford’s new 2020 F-Series Super Duty will start shipping to dealers this fall.
  • My Clubs
  • Recently Browsing
    No registered users viewing this page.
  • Reader Rides
