Ford News: Rumorpile: Next Ford Fiesta ST Could Get 3-Cylinder Turbo Power
William Maley
The current Ford Fiesta ST uses a 1.6L EcoBoost four-cylinder. But the next-generation Fiesta ST could be using a turbocharged three-cylinder.
“We’re seeing more and more of what we can do with the 1.0-litre engine in development and the signs are promising. It’s a great engine – it sounds brilliant and there’s loads of torque when the turbo comes on boost, so we’re looking into things for the next ST,” said Darren Palmer, Ford's head of small cars to Auto Express.
Currently, the most powerful version of the 1.0L EcoBoost three-cylinder produces 138 horsepower. But Ford has been experimenting with the engine to see how much power can be extracted. At the moment, the company has been able to get 202 horsepower.
“There’s still a huge demand for the ST – we’ve seen that with the current ST200. But we want to offer more, so expect more performance and efficiency,” said Palmer.
Source: Auto Express
5 minutes ago, ccap41 said:
This isn't VW news...
Anyway, as long as they keep it quite powerful this thing will still be a blast to drive. I'm yet to drive one but I don't think I've read a bad thing about them.
Quite tempted buy the current model myself.
44 minutes ago, Wings4Life said:
If you note his remarks, he does not state that it would be 1.0L.
Fact is, it would be much bigger.  And fewer cylinders is always better, assuming similar displacements.
For fuel economy / internal friction.... sure. Not always on balance and revving. (i.e. a 3.0 liter V8 will be smoother and rev faster than a 3.0 liter 4-cylinder assuming the same valvetrain setup)
However, even the 5-cylinder engines I've driven have been fairly disappointing on that front (Volvo excepted). All the fuel economy of a V6 with all the power of a N/A 4-cylinder.
That said.... I do think the 1.0 Ecoboost is the superior engine in the Fiesta. It's not a smooth as the 4-cylinder, but it has a fun growl.
Compare a 1.5L I4 and I3,
I3 packages far smaller and easier
I3 weighs far less
I3 has far less friction and better FE
I3 has much bigger bore, which mostly benefits larger valves and more airflow
I3 GTDI will rev faster and just as smooth
I3 Structure is stronger (length of crank, gearbox, etc.)
A 1.0L works harder due to less power, and is a bit more NVH, but that cancels out when you have similar displacements/power
I3 weighs far less
I don't disagree with most of those.  I took issue with the "always".
Assuming all else equal on an I4 and I3, the 3 won't be as smooth, simple mathematical balance dictates that. Revving faster is also only a maybe... with the bigger bores comes more mass moving in each cylinder. Each time one of those three chunks of mass have to slow down, stop, and change direction there is inertia to overcome.  This is an oversimplification, but each piston will weigh 1/3rd more than in an I-4 (again, all else being equal).  While the total number of piston direction changes happens more often in an I4, the mass of each of those pistons is lower.
This is born out historically...generally small V8s rev better than big V6es. Small V6es rev better than big I4s.
I like the I-3. I think it has a strong future ahead.... I'm just reluctant to attribute things to it that aren't really there.
There are balance tricks to mitigate it, without adding weight and extensive engineering. You counter externally, and balance as a system, including the mounts.  That's what they did with the 1.0L.   But I am sure you knew that.  But again, with boosted engines, they are both quieter and smoother due to not need to rev.  In general.  Most reviews of the 1.0L praised it's smoothness, quick revving and growl.
So again, on a same displacement comparison,
smoothness will be similar, as delivered.
It will be rev happy, even with the bigger bore, and it is stroke that impacts that more than bore size.
and the growl will be even better, due to bigger bore and chamber.
All of those tricks mean that they aren't equal... which was precisely my point.... all else being equal... an I4 will be better balanced and smoother than an I3.  I'm not discouraging the use of those tricks either... Buick used a few of them in the Encore and it's noticeable that they didn't make it into the Trax.
I'm very precise with my statements.
Tricks?  It’s called balancing a motor.  Something every motor should and does do.  They just approach it different with the I3.  That’s not a ‘trick’ when you tune a system properly, as a system.
Precise with your words?
Not in this case.
But I think we are both getting a bit mixed up here in our terms. Let’s review:
 An I3 actually vibrates less than an I4, because there is no piston pairing, so some might call it smoother than an I4, especially at higher rpm.  An I4 is actually a bit smoother, but vibrates  more at higher RPM, due to the piston pairing and phasing at 180deg.  An I6 is also paired, but benefits from perfect phase balance of 120.  The I3 has a 240 phase and looks like a Y viewed at the end of the crank. That is closer to an I6 in appearance, than an I4 at 180. And  in total, it’s about counterweight placement and their  phasing.  Or more specifically, the conservation of momentum, or how the piston/rod counterweight is configured to counter the reciprocating and rotating mass.
And although a powertrain design engineer analyst by trade and certainly know a thing or two about what I speak, I am too humble to state I use precise words. I am human after all, and mistakes happen.
Edited by Wings4Life
2 hours ago, Wings4Life said:
Humming along on dyno's at the moment.
It's only a fact if it is provable. Otherwise you sound like the other guy who overused that word.
Wanna show us some inside news on the new motor?!? NEVER BEFORE SEEN FOOTAGE?!?(not being a smartass but I realize this cannot be done..so maybe that is being a smartass.. well I'm just jokin around. )
The forum world was busy discussing the new and larger I3 and I4 family from Ford recently, complete with a code project name.  I assumed everyone heard about it. hence my subtle reference to it.  Perhaps you have not heard it here.
And normally I would share what I can, but lately, with all the down-talking and rudeness around here, I would rather not.  Why would I.
Thanks
Guest Wings on cell phone
Yes.. a trick. Active motor mounts are tricks used to hide/tame engine imbalance. So are counter rotating balance shafts. So is active noise cancellation.
None of which is used with the 1.0l.
hence no tricks
We've been talking engines...was i rude to an engine?
Did someone suggest you have been rude.
I'm all for mechanical entertainment.  I was high on the 1.0 EB in the Fiesta until I realized Ford would only pair it with a car that has plastic wheel covers and no FOG LIGHTS.  Who does that?
Local dealer has a black Focus hatch with the 1.0L and stick on the lot.  Hmmm...
  • Social Stream
  • Similar Content
    • By David
      Since Ford Motor Company reported a complete Q4 / 2020 fiscal year report with a loss of $2.8 Billion but a doubling of R&D on EVs to $22 Billion from $11 Billion and a $7 Billion for EV Autonomous driving, the auto reporters are asking this very question: Is this a Shot across gm's bow or is it targeted more broadly across the whole industry as everyone wants to take sales away or greatly slow down Tesla.
      Tesla's valuation appears to be based on investors putting money with new technology seems to be driving changes of the future.
      gm has now committed to moving into the technology camp with a solid date of when new ICE auto's will no longer be produced as the whole portfolio will change over to EV's. Ford also is now committing to this same strategy. This now makes one wonder about the rest of the auto industry.
      Stellantis CEO did an interview with Forbes that has put cold water on Peugeot coming to the US in the near term future as he wants to invest in the existing US name brands and grow their 12.7% market share. He also said that Stellantis has the manufacturing power and EV technology, but getting it into the hands of everyone is the concern at reasonable prices. Stellantis CEO says this is in the hands of the various global governments as he wants cleaner air and believes diesel the dirtiest of fuels will die off before regular petrol and where dictated by governments such as China and Europe will see a faster change over than other countries. Yet with the change in administration in the US, he says this could move the Stellantis brands to move into the full EV camp at a future date.
      Then we have small countries that have decided to make a major change in moving the country into EVs way sooner than other places and killing ICE sales like Thailand. This will allow local Thai startups to compete for the first time with international companies that also do not have anything in the market yet.
      With a large range of battery plants coming online over the next 18 months, the move to EVs could happen at a pace that took decades for ICE in the early 1900's.
      So this brings this back to the original question, Is Fords Doubling commitment to EV's and moving ICE into the last generation like GM a shot across GM's bow or a shot at the whole industry to say, look at us, we are moving into a Technology driven auto company and our stock should be much higher like Tesla's.
      Currently gm is valued at just under $80 Billion, Ford is valued at $40 Billion, Tesla is valued at $807 Billion, Toyota is valued at $155.5 Billion, Stellantis is valued at $50.5 Billion, Daimler is valued at $71 Billion, BMW valued at $46 and VW is valued at $90.7 Billion and while there are plenty of other auto companies, one has to wonder what Ford is focused on with the drastic change and speeding up of moving to EVs as a complete global portfolio.
      Sound off and discuss how, what, where and when you think this will have it's big affect.
      Charged EVs | Is Ford’s increase in EV investment a shot across GM’s bow? - Charged EVs
      Stellantis CEO Reveals Peugeot U.S. Fate, Job Security, EV Conflict (forbes.com)
      Future Toyotas, Stellantis, batteries and EVs - the week | Automotive Industry Comment | just-auto (just-auto.com)
    • By William Maley
      We've been reporting on Ford's upcoming truck, the Maverick since 2018. The truck would sit underneath the Ranger and become the entry-level model for the brand. Now, we have gotten our best look at what it will look like.
      The Maverick Truck Club forum got its hand on an image showing a prototype Maverick on the line reportedly at Ford's Hermosillo, Mexico plant. Up front, the Maverick borrows some ideas from the Bronco Sport with C-shaped headlights and a horizontal bar splitting the grille. We don't know if Ford is planning to offer any cab configurations aside from the crew-cab seen in the photo.
      Ford did not immediately reply to comment on this when reached out by Roadshow.
      The Maverick is expected to use the C2 architecture which underpins the new Escape and Bronco Sport. Autoblog speculates there could be two rear suspension setups based on spy shots that show a mule with twist-beam style setup with no rear differential for the front-wheel driver version. A slightly beefier setup might be used for the all-wheel drive version.
      Right now, everyone seems to think that the Maverick could debut as a 2022 model year vehicle.
      Source: Maverick Truck Club, Roadshow, Autoblog
      Pic Credit: Maverick Truck Club
    • By William Maley
    • By William Maley
      Jim Hackett's tenure as Ford CEO will be coming to a close on October 1st as he will retire from the position. His replacement is Jim Farley, currently Ford's Chief Operating Officer, a role he took on at the beginning of this year. In a press release, Ford said the two will be working together over the next two months on the transition. Hackett will stay on as "special advisor" for some time after.
      “I am very grateful to Jim Hackett for all he has done to modernize Ford and prepare us to compete and win in the future. Our new product vision – led by the Mustang Mach-E, new F-150 and Bronco family – is taking shape. We now have compelling plans for electric and autonomous vehicles, as well as full vehicle connectivity. And we are becoming much more nimble, which was apparent when we quickly mobilized to make life-saving equipment at the outset of the pandemic,” said Ford executive chairman, Bill Ford.
      Hackett became Ford's CEO in 2017 after the ousting of then CEO Mark Fields. His short tenure brought forth some major and controversial decisions such as Ford killing off most of their passenger car nameplates to focus on trucks and utility vehicles; spending $11 billion in electric vehicles by 2022, and the introductions of the Mach-E, 2021 F-150, and Bronco. He has also dealt with a lot frustration from various groups as The Detroit News outlines,
      Hackett admitted that his tenure did cause a fair amount of friction, but said his efforts are starting to show.
      "I aimed for moving ahead versus just moving fast. Could we aim for a longer-arc kind of reward. In this case, for the three years it takes to get products to market, you're starting to see the fruits of our labor."
      Farley, who has been with Ford since 2007, knows he has a tough road ahead. Aside from realizing the various paths laid out by Hackett, he also has to deal with the issues of the COVID-19 pandemic and hopefully launch two of Ford's key product without any issues.
      Source: Ford
      Press Release is on Page 2
      FORD ANNOUNCES JIM HACKETT TO RETIRE AS PRESIDENT AND CEO; JIM FARLEY TO SUCCEED HACKETT AS COMPANY CONTINUES TRANSFORMATION
      Jim Hackett, who has led Ford Motor Company’s transformation since 2017 as president and CEO, has elected to retire from the company Jim Farley, currently chief operating officer, becomes president and CEO of Ford effective Oct. 1. He was also elected to the Ford board of directors. He will work closely with Jim Hackett on the transition over the next two months Seamless CEO transition underscores strength of Ford’s leadership team, succession planning, and company progress over the past three years, Executive Chairman Bill Ford says DEARBORN, Mich., Aug. 4, 2020 – Ford Motor Company today announced that Jim Hackett, who has led the company’s transformation since 2017, plans to retire from the company. Jim Farley has been named the company’s new president and CEO and will join the board of directors, effective Oct. 1.
      Hackett, 65, and Farley, 58, will work together on a smooth leadership transition over the next two months.
      Under Hackett, Ford moved aggressively into the new era of smart vehicles and drove a deeper focus on customers’ wants and needs. At the same time, Ford improved the fitness of the base business – restructuring operations, invigorating the product portfolio and reducing bureaucracy.
      “I am very grateful to Jim Hackett for all he has done to modernize Ford and prepare us to compete and win in the future,” said Bill Ford, Ford’s executive chairman. “Our new product vision – led by the Mustang Mach-E, new F-150 and Bronco family – is taking shape. We now have compelling plans for electric and autonomous vehicles, as well as full vehicle connectivity. And we are becoming much more nimble, which was apparent when we quickly mobilized to make life-saving equipment at the outset of the pandemic.”
      Farley, an automotive leader with deep global experience and a successful track record, collaborated with Hackett over the past three years to develop and execute Ford’s Creating Tomorrow Together plan to transform Ford into a higher-growth, higher-margin business.
      “Jim Farley matches an innate feel for cars and customers with great instincts for the future and the new technologies that are changing our industry,” Bill Ford said. “Jim’s passion for great vehicles and his intense drive for results are well known, and I have also seen him develop into a transformational leader with the determination and foresight to help Ford thrive into the future.”
      Farley joined Ford in 2007 as global head of Marketing and Sales and went on to lead Lincoln, Ford South America, Ford of Europe and all Ford global markets in successive roles. In April 2019, Farley was chosen to lead Ford’s New Businesses, Technology & Strategy team, helping the company determine how to capitalize on powerful forces reshaping the industry – such as software platforms, connectivity, AI, automation and new forms of propulsion. He was named chief operating officer in February of this year.
      Hackett, who will continue as a special advisor to Ford through March of 2021, said the time is right to pass the mantle of leadership to Jim Farley.
      “My goal when I took on the CEO role was to prepare Ford to win in the future,” Hackett said. “The hardest thing for a proud, long-lived company to do is change to meet the challenges of the world it’s entering rather than the world it has known. I’m very proud of how far we have come in creating a modern Ford and I am very optimistic about the future.
      “I have worked side-by-side with Jim Farley for the past three years and have the greatest confidence in him as a person and a leader,” Hackett said. “He has been instrumental in crafting our new product portfolio and redesigning our businesses around the world. He is also a change agent with a deep understanding of how to lead Ford in this new era defined by smart vehicles in a smart world.”
      Said Farley: “I love Ford and I am honored by the opportunity to serve and create value for Ford’s employees, customers, dealers, communities and all of our stakeholders. Jim Hackett has laid the foundation for a really vibrant future and we have made tremendous progress in the past three years. I am so excited to work together with the whole Ford team to realize the full potential of this great company in a new era.”
  • Reader Rides
